17267 Discussions
ModelSim and filename length limit
I'm currently trying to simulate the Hard memory controller example, and the files in "vhdl/submodules" are very long. For some reason modelsim fails to read any of the files with filenames greater than 83 characters !?? I'm running Quartus/modelsim under Windows XP 64 bit, a work colleague has Windows 7 64 bit, and modelsim has no problems reading the same files !
Any help would be much appreciated
Lee
put your project into a subfolder directly over a HDD for example D:\ms
--- Quote Start ---
put your project into a subfolder directly over a HDD for example D:\ms\
--- Quote End ---
Hi, just tried that, still the same.
Lee
Transcript is :-
# -- Loading package STANDARD
# -- Loading package TEXTIO
# -- Loading package std_logic_1164
# -- Compiling entity ddr_uniphy_hc_example_sim_e0_if0_id_router
# -- Compiling architecture RTL of ddr_uniphy_hc_example_sim_e0_if0_id_router
# Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012
# -- Compiling entity ddr_uniphy_hc_example_sim_e0_if0_addr_router
# -- Compiling architecture RTL of ddr_uniphy_hc_example_sim_e0_if0_addr_router
# ** Error: (vcom-7) Failed to open design unit file "./..//submodules/ddr_uniphy_hc_example_sim_e0_if0_c0_csr_translator_avalon_universal_slave_0_agent_rdata_fifo.vho" in read mode.
# No such file or directory. (errno = ENOENT)
# ** Error: C:/altera/13.0/modelsim_ase/win32aloem/vcom failed.
# Error in macro ./run.do line 11
# C:/altera/13.0/modelsim_ase/win32aloem/vcom failed.
# while executing
# "vcom "$QSYS_SIMDIR/submodules/ddr_uniphy_hc_example_sim_e0_if0_c0_csr_translator_avalon_universal_slave_0_agent_rdata_fifo.vho" "
# ("eval" body line 42)
# invoked from within
# "com"
# "if {[file exists msim_setup.tcl]} {
# source msim_setup.tcl
# dev_com
# com
# # the "elab_debug" macro avoids optimizations which preserves signals so tha..."
If I shorten "ddr_uniphy_hc_example_sim_e0_if0_c0_csr_translator _avalon_universal_slave_0_agent_rdata_fifo.vho" to "ddr_uniphy_hc_example_sim_e0_if0_c0_csr_translator _avalon_universal_slave_0_agent_r.vho" (83 characters) it finds it !
Windows XP has a limit on the total pathname length of 250 chars, not on the filename length. The pathname includes the starting "C:\" and null and the end of the path.
--- Quote Start ---
--- Quote End ---
Thanks to both you (dave_59) and Taz1984, I forgot to rename the vho file back to its original name, after doing this all files are now found if I move the sim project to say c:\ms\ to minimise total pathname length :-)
Many Thanks
Lee
Thanks, made interesting reading, same problem I had, I also can't believe the filenames have to be so long either !
Yep, not only did they leave their brains at home on the day that they created those long filenames but there was an astonishing lack of testing.
