17268 Discussions
ModelSim executable Error Message
BA26
I have downloaded Quartus Prime Lite 20.1.1 again and continue to receive this error message every time I try to use the University Waveform VWF:( ModelSim executable not found in C:/altera/13.1/modelsim_ase/win32aloem Error. ) How can I fix this? Thank you.Error MessageError Message
Nurina
Hi Brianna,
You need to specify your ModelSim executable directory. To do this, go to Tools>Options>EDA Tools Options.
At the ModelSim directory, add an extra "/" at the end of the path name like so: "C:/altera/13.1/modelsim_ase/win32aloem/"
There is an old discussion thread regarding this issue that you can refer to: https://community.intel.com/t5/Intel-Quartus-Prime-Software/Can-t-launch-the-Modelsim-Altera-Software/td-p/163728
I hope this solves your issue. Let me know if your issue persists.
Nurina
BA26
Hi Nurina,
Ok, so I added the extra "/" add the end of the Modelsim executable Directory and I still received the same error message.
Nurina
Hi Brianna,
It seems that the path directory is not correct. Replace 13.1 with 20.1 in the path directory like so: "C:/altera/20.1/modelsim_ase/win32aloem/".
Make sure the path directory is correct; change it according to your installation directory path. You can check your computer for this. It might be under "C:/intelFPGA_lite/20.1/modelsim_ase/win32aloem/", and if so, change your path directory on Quartus following the aforementioned address.
If your issue isn't resolved, make sure your ModelSim is selected in your EDA settings. To do this, go to Assignments>Settings>EDA Tool Settings>Simulation and make sure you have ModelSim selected under tool name.
Note: If both ModelSim and ModelSim-Altera are available it would select ModelSim-Altera by default. You may need to repeat this process every time you open Quartus again depending on your OS.
Nurina
Nurina
Hi Brianna,
Is your problem resolved?
Nurina
Ivan18
Hello, im having the same error but it doesnt change with the solutions proposed
Mcq
Hey did you solve it?? If yes I'm getting the same error can you help me.
