17255 Discussions
Modelsim Simulator Error & Request about solutions and source files
Junmo
I have a two questions.
First,
I use the quartus 18.1 version and run gate level simulation using VWF.
I can see the simulation waveform result  but in this waveform the delay isn't considered. The output signal has  a 0ns delay.
During simulation log,
The "Error: can't read "FileWatch(filename)": no such element in array" message was shown.
What does this message mean? Can it occur the 0ns delay problem?
Second,
I requested the solutions and source files about lab in this page (Solution Request for Intel® FPGA Academic Program) about 10 days ago.
But I didn't get any response.
Next semester, I will teach the subject using  Intel FPGA training kit which
has the Cyclone II and V.
I need the solutions and source files about courses ASAP.
hareesh
Hi Junmo,
Can you please share your simulation file.
Junmo
Hi.
This is a waveform.
The circuit is very simple(Full Adder).  The inputs are a, b, cin.
hareesh
Hi @Junmo,
i think this is a vwf limitation. I would recommend the users to use the questasim. for Questasim reference video link sharing here.
https://www.youtube.com/watch?v=60-beTWcJSM
Junmo
Thanks for your response. I will try it.
hareesh
Hi
APAS files access issue requested to IT team from my side. did get any id number or requested  mail id to identify you request.
Junmo
My mail addr. is jmjung@kunsan.ac.kr.
hareesh
Hi
I sharing customer support for ASAP issue. pls contact there.
 if you don't have any another quire i'll close the case. pls conform me.
https://it.intel.com/#/topic/5457
Junmo
I can't access that link. Is that right?
Would you mind checking that link?
And, I got the solutions today morning. But I couldn't solve 0ns delay on Gate level simulation in VWF.
hareesh
Hi
Did you tried in Modelsim?
Junmo
Yes.
I runned the Gate level simulaion  on Quartus II 18.1 version using VWF university program.
hareesh
Hi @Junmo ,
I think in your design you are not using CLK. for reference i am sharing full adder VHDL code(i am not good in Verilog HDL, so i sharing VHDL) and simulation output files. Go through bellow attached files.
hareesh
I think you got solution for your issue. if you don't have any quires I'll close the case. pls respond.
Junmo
Ok.
Thanks for your help.
hareesh
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
