16608 Discussions
Modelsim: Unresolved defparam reference to somewhere
In Quartus ii schematic diagram, i've generated an lpm_ff. Then i've converted the design to a .v file. when i want to use this flip-flop in a module, it compiles with no problems but when i want to simulate it with modelsim i receive this error for all defparams in the code in the :
Error: (vsim-10000) C:/.../lpm_ff_8.v(30): Unresolved defparam reference to 'LPM_WIDTH' in lpm_instance.LPM_WIDTH.
Here is the code of `ff` that Quartus generated:
module lpm_ff_8(clock,sload,data,q); input clock; input sload; input data; output q; lpm_ff lpm_instance(.clock(clock),.sload(sload),.data(data),.q(q)); defparam lpm_instance.LPM_AVALUE = 1; defparam lpm_instance.LPM_FFTYPE = "DFF"; defparam lpm_instance.LPM_SVALUE = 0; defparam lpmi_nstance.LPM_WIDTH = 16; endmodule
And the module i use this flip-flop in it:
module test(input a, clk, output reg q); lpm_ff_8 regg(.data(a), .clock(clk), .q(q)); endmodule module testTB(); reg a; reg clk; wire q; test t(a, clk, q); initial begin # 15 clk = 1; end endmodule
I also add lpm_ver library when i want to simulate. So can you help me to find what's wrong with this code?
1. Here is Typo mistake,
Defparam lpmi_nstance.LPM_WIDTH = 16; ---> lpm_instance.LPM_WIDTH
2. Missed port sload while instantiation & declare all inputs & outputs before use it & then instantiate,
note: unfortunately handled old thread while handling thread 59117
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
