The message is displayed while executing the simulation.
「Modelsim is exiting with code 9」# ** Fatal: (vsim-4) ***** Momory allocation failure. *****# Please check your system for available memory and swap space. Now, momory is 2GB and swap sizes is 5000MB How much are necessary PC specs? Besides the memory, is there a cause?Link Copied
Did you try using the -novopt option on your vsim command.
I try the -novopt ,but the problem still exist. is there any other cause?
