17105 Discussions
Mutiplexer giving high impedance while connected serially to a D-Flip Flop
Hi guys,
I am very much new to verilog and I have been trying to replicate an LUT-FF pair with a multiplexer to select the output from either directly from the LUT or from the D-FF. When I tried connecting all three modules, I found that the LUT output is coming as 'Z'. I have individually tested all three modules (LUT, D-FF and 2x1 MUX) and they are working fine. I think something might be wrong with my test bench but I am not able to find out the issue.
Please find the code below. Any kind of help is much appreciated.
module test_bench();
wire MuxOut;
reg [15:0] In;
reg [3:0] sel;
reg clk,reset,switch;
logic_pair LUTFF(.inp(sel),.lut(In),.sel(switch),.clk(clk),.reset(reset),.out(MuxOut));
initial begin
// Initiliase Input Stimulus
clk = 1'b0;
reset=1'b1;
switch=1'b0;
In = 16'b1100_0011_1011_0101;
sel=4'b0000;
forever# 100 clk=!clk;
end
always @(posedge clk)
begin # 5;
sel=4'b0000;
reset=1'b0;
switch=0;# 10;
sel=4'b0001;
switch=0;
reset=1'b0;# 10;
sel=4'b0010;
switch=0;
reset=1'b0;# 10;
reset=1'b1;
switch=1;
sel=4'b1000;
sel=4'b1000;
sel=4'b0100;# 400 $finish;
end
initial begin
$dumpfile("x.vcd");
$dumpvars(0,test_bench);
$timeformat(-9, 1, " ns", 6);
$monitor("At t=%t sel=%b In=%b_%b MuxOut=%b reset=%b switch=%b",$time,sel,In[15:8],In[7:0],MuxOut,reset,switch);
end
//Stimulus
endmodule
module logic_pair(inp,lut,sel,clk,reset,out);
input [15:0] lut;
input [3:0] inp;
input sel;
input clk,reset;
output out;
wire out_lut,out_ff;
LU L1(.in1(lut), .in2(inp), .out2(out_lut));
syn_D_FF FF1(.data_in(out_lut),.clk(clk),.reset(reset),.data_out(out_ff));
MUX_FF_LUT FF_LUT(.lut(out_lut),.ff(out_ff),.sel(sel),.out(out));
endmodule
module LU(in1, in2, out2);
input wire [15:0] in1;
input wire [3:0] in2;
output reg out2;
always@(in2 or in1)
case (in2)
4'b0000: out2 <= in1[0];
4'b0001: out2 <= in1[1];
4'b0010: out2 <= in1[2];
4'b0011: out2 <= in1[3];
4'b0100: out2 <= in1[4];
4'b0101: out2 <= in1[5];
4'b0110: out2 <= in1[6];
4'b0111: out2 <= in1[7];
4'b1000: out2 <= in1[8];
4'b1001: out2 <= in1[9];
4'b1010: out2 <= in1[10];
4'b1011: out2 <= in1[11];
4'b1100: out2 <= in1[12];
4'b1101: out2 <= in1[13];
4'b1110: out2 <= in1[14];
4'b1111: out2 <= in1[15];
endcase
endmodule
module MUX_FF_LUT(lut,ff,sel,out);
input lut,ff,sel;
output reg out;
always@(sel)
begin
case (sel)
1'b0: out <= lut;
1'b1: out <= ff;
//default : out <= lut;
endcase
end
endmodule
module syn_D_FF(data_in,data_out,clk,reset);
input data_in;
input clk,reset;
output reg data_out;
always@(posedge clk or negedge reset)
begin
if(reset)
data_out<=1'b0;
else
data_out<=data_in; end
endmodule
Hi!
The "always@(posedge clk or negedge reset)" statement should be "always@(posedge clk or posedge reset)" as you trigger on a rising reset input.
And you should use a complete sensitivity list (all signals at the right side of "=") at:
"always@(sel)". Or the simple way: "always @*"
Use "=" instead of "<=" in combinatorial blocks ("always @*").
With these changes your output should be 1'b0 or 1'b1 instead of x.
--- Quote Start ---
Hi!
--- Quote End ---
Thanks a lot!! Now the code is working perfectly
@DUESTERBERG Thanks a lot!!! Now the code is working perfectly
