Hi guys,
I am very much new to verilog and I have been trying to replicate an LUT-FF pair with a multiplexer to select the output from either directly from the LUT or from the D-FF. When I tried connecting all three modules, I found that the LUT output is coming as 'Z'. I have individually tested all three modules (LUT, D-FF and 2x1 MUX) and they are working fine. I think something might be wrong with my test bench but I am not able to find out the issue. Please find the code below. Any kind of help is much appreciated. module test_bench(); wire MuxOut; reg [15:0] In; reg [3:0] sel; reg clk,reset,switch; logic_pair LUTFF(.inp(sel),.lut(In),.sel(switch),.clk(clk),.reset(reset),.out(MuxOut)); initial begin // Initiliase Input Stimulus clk = 1'b0; reset=1'b1; switch=1'b0; In = 16'b1100_0011_1011_0101; sel=4'b0000; forever# 100 clk=!clk; end always @(posedge clk) begin # 5; sel=4'b0000; reset=1'b0; switch=0;# 10; sel=4'b0001; switch=0; reset=1'b0;# 10; sel=4'b0010; switch=0; reset=1'b0;# 10; reset=1'b1; switch=1; sel=4'b1000; sel=4'b1000; sel=4'b0100;# 400 $finish; end initial begin $dumpfile("x.vcd"); $dumpvars(0,test_bench); $timeformat(-9, 1, " ns", 6); $monitor("At t=%t sel=%b In=%b_%b MuxOut=%b reset=%b switch=%b",$time,sel,In[15:8],In[7:0],MuxOut,reset,switch); end //Stimulus endmodule module logic_pair(inp,lut,sel,clk,reset,out); input [15:0] lut; input [3:0] inp; input sel; input clk,reset; output out; wire out_lut,out_ff; LU L1(.in1(lut), .in2(inp), .out2(out_lut)); syn_D_FF FF1(.data_in(out_lut),.clk(clk),.reset(reset),.data_out(out_ff)); MUX_FF_LUT FF_LUT(.lut(out_lut),.ff(out_ff),.sel(sel),.out(out)); endmodule module LU(in1, in2, out2); input wire [15:0] in1; input wire [3:0] in2; output reg out2; always@(in2 or in1) case (in2) 4'b0000: out2 <= in1[0]; 4'b0001: out2 <= in1[1]; 4'b0010: out2 <= in1[2]; 4'b0011: out2 <= in1[3]; 4'b0100: out2 <= in1[4]; 4'b0101: out2 <= in1[5]; 4'b0110: out2 <= in1[6]; 4'b0111: out2 <= in1[7]; 4'b1000: out2 <= in1[8]; 4'b1001: out2 <= in1[9]; 4'b1010: out2 <= in1[10]; 4'b1011: out2 <= in1[11]; 4'b1100: out2 <= in1[12]; 4'b1101: out2 <= in1[13]; 4'b1110: out2 <= in1[14]; 4'b1111: out2 <= in1[15]; endcase endmodule module MUX_FF_LUT(lut,ff,sel,out); input lut,ff,sel; output reg out; always@(sel) begin case (sel) 1'b0: out <= lut; 1'b1: out <= ff; //default : out <= lut; endcase end endmodule module syn_D_FF(data_in,data_out,clk,reset); input data_in; input clk,reset; output reg data_out; always@(posedge clk or negedge reset) begin if(reset) data_out<=1'b0; else data_out<=data_in; end endmoduleLink Copied
Hi!
The "always@(posedge clk or negedge reset)" statement should be "always@(posedge clk or posedge reset)" as you trigger on a rising reset input. And you should use a complete sensitivity list (all signals at the right side of "=") at: "always@(sel)". Or the simple way: "always @*" Use "=" instead of "<=" in combinatorial blocks ("always @*"). With these changes your output should be 1'b0 or 1'b1 instead of x.- Mark as New
--- Quote Start --- Hi! The "always@(posedge clk or negedge reset)" statement should be "always@(posedge clk or posedge reset)" as you trigger on a rising reset input. And you should use a complete sensitivity list (all signals at the right side of "=") at: "always@(sel)". Or the simple way: "always @*" Use "=" instead of "<=" in combinatorial blocks ("always @*"). With these changes your output should be 1'b0 or 1'b1 instead of x. --- Quote End --- Thanks a lot!! Now the code is working perfectly
@DUESTERBERG Thanks a lot!!! Now the code is working perfectly
