All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
NIOS/IP migration
amildm
Valued Contributor I
Hi All,
I need to migrate the NIOS prom one Quartus project to another.…
What's the proper way to do so?
Thank you!
EricMunYew_C_Intel
You can copy the generated Nios to another project folder. In Platform Designer, click Refresh, and your generated Nios will appear under System, and then you can add it in your top level.
You can maintain your Quartus Pro v19.3 in Platform Designer without upgrading.
