17258 Discussions
Need help with VHDL error here
Error (10476): VHDL error at scomp.vhd(64): type of identifier "AC_SHIFTED" does not agree with its usage as "std_logic_vector" type
Error (10558): VHDL error at scomp.vhd(64): cannot associate formal port "RESULT" of mode "out" with an expression
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
LIBRARY ALTERA_MF;
USE ALTERA_MF.ALTERA_MF_COMPONENTS.ALL;
LIBRARY LPM;
USE LPM.LPM_COMPONENTS.ALL;
ENTITY SCOMP IS PORT(
CLOCK : IN STD_LOGIC;
RESETN : IN STD_LOGIC;
PC_OUT : OUT STD_LOGIC_VECTOR( 9 DOWNTO 0);
AC_OUT : OUT STD_LOGIC_VECTOR(15 DOWNTO 0);
MDR_OUT : OUT STD_LOGIC_VECTOR(15 DOWNTO 0);
MAR_OUT : OUT STD_LOGIC_VECTOR( 9 DOWNTO 0);
IO_WRITE : OUT STD_LOGIC;
IO_CYCLE : OUT STD_LOGIC;
IO_ADDR : OUT STD_LOGIC_VECTOR( 7 DOWNTO 0);
IO_DATA : INOUT STD_LOGIC_VECTOR(15 DOWNTO 0)
END SCOMP;
ARCHITECTURE a OF SCOMP IS
TYPE STATE_TYPE IS (
RESET_PC,
FETCH,
DECODE,
EX_LOAD,
EX_STORE,
EX_STORE2,
EX_ADD,
EX_SUB,
EX_JNEG,
EX_JPOS,
EX_JZERO,
EX_JUMP,
EX_AND,
EX_OR,
EX_XOR,
EX_ADDI,
EX_SHIFT,
AC_SHIFTED
SIGNAL STATE : STATE_TYPE;
SIGNAL AC : STD_LOGIC_VECTOR(15 DOWNTO 0);
SIGNAL IR : STD_LOGIC_VECTOR(15 DOWNTO 0);
SIGNAL MDR : STD_LOGIC_VECTOR(15 DOWNTO 0);
SIGNAL PC : STD_LOGIC_VECTOR(9 DOWNTO 0);
SIGNAL MEM_ADDR : STD_LOGIC_VECTOR(9 DOWNTO 0);
SIGNAL MW : STD_LOGIC;
BEGIN
SHIFTER: LPM_CLSHIFT -- Use LPM_CLSHIFT to shift AC
GENERIC MAP(
lpm_width => 16,
lpm_widthdist => 4,
lpm_shifttype => "LOGICAL"
PORT MAP(
data => AC,
distance => IR(3 downto 0),
direction => IR(4),
result => AC_SHIFTED <----1st and 2nd error here
MEMORY : altsyncram -- Use altsyncram component for unified program and data memory
GENERIC MAP (
intended_device_family => "Cyclone",
width_a => 16,
widthad_a => 10,
numwords_a => 1024,
operation_mode => "SINGLE_PORT",
outdata_reg_a => "UNREGISTERED",
indata_aclr_a => "NONE",
wrcontrol_aclr_a => "NONE",
address_aclr_a => "NONE",
outdata_aclr_a => "NONE",
init_file => "TEST_CODE.mif",
lpm_hint => "ENABLE_RUNTIME_MOD=NO",
lpm_type => "altsyncram"
PORT MAP(
wren_a => MW,
clock0 => NOT(CLOCK),
address_a => MEM_ADDR,
data_a => AC,
q_a => MDR
PC_OUT <= PC;
AC_OUT <= AC;
MDR_OUT <= MDR;
MAR_OUT <= MEM_ADDR;
IO_WRITE <= '0';
IO_CYCLE <= '0';
IO_ADDR <= IR(7 DOWNTO 0);
WITH STATE SELECT
MEM_ADDR <= PC WHEN FETCH,
IR(9 DOWNTO 0) WHEN OTHERS;
PROCESS (CLOCK, RESETN)
BEGIN
IF (RESETN = '0') THEN -- Active low, asynchronous reset
STATE <= RESET_PC;
ELSIF (RISING_EDGE(CLOCK)) THEN
CASE STATE IS
WHEN RESET_PC =>
MW <= '0'; -- Clear memory write flag
PC <= "0000000000"; -- Reset PC to the beginning of memory, address 0x000
AC <= x"0000"; -- Clear AC register
STATE <= FETCH;
WHEN FETCH =>
IR <= MDR; -- Latch instruction into the IR
PC <= PC + 1; -- Increment PC to next instruction address
STATE <= DECODE;
WHEN DECODE =>
CASE IR(15 downto 10) IS
WHEN "000000" => -- No Operation (NOP)
STATE <= FETCH;
WHEN "000001" => -- LOAD
STATE <= EX_LOAD;
WHEN "000010" => -- STORE
STATE <= EX_STORE;
WHEN "000011" => -- ADD
STATE <= EX_ADD;
WHEN "000100" => -- SUB
STATE <= EX_SUB;
WHEN "000101" => -- JUMP
STATE <= EX_JUMP;
WHEN "000110" => -- JNEG
STATE <= EX_JNEG;
WHEN "000111" => -- JPOS
STATE <= EX_JPOS;
WHEN "001000" => -- JZERO
STATE <= EX_JZERO;
WHEN "001001" => -- AND
STATE <= EX_AND;
WHEN "001010" => -- OR
STATE <= EX_OR;
WHEN "001011" => -- XOR
STATE <= EX_XOR;
WHEN "001101" => -- ADDI
STATE <= EX_ADDI;
WHEN "001100" => -- SHIFT
STATE <= EX_SHIFT;
WHEN OTHERS =>
STATE <= FETCH; -- Invalid opcodes default to NOP
END CASE;
WHEN EX_LOAD =>
AC <= MDR; -- Latch data from MDR (memory contents) to AC
STATE <= FETCH;
WHEN EX_STORE =>
MW <= '1'; -- Raise MW to write AC to MEM
STATE <= EX_STORE2;
WHEN EX_STORE2 =>
MW <= '0'; -- Drop MW to end write cycle
STATE <= FETCH;
WHEN EX_ADD =>
AC <= AC + MDR;
STATE <= FETCH;
WHEN EX_SUB =>
AC <= AC - MDR;
STATE <= FETCH;
WHEN EX_JUMP =>
PC <= IR(9 DOWNTO 0);
STATE <= FETCH;
WHEN EX_JNEG =>
IF AC(15) = '1' THEN
PC <= IR(9 downto 0);
END IF;
STATE <= FETCH;
WHEN EX_JPOS =>
IF AC(15) = '0' AND AC /= x"0000" THEN
END IF;
STATE <= FETCH;
WHEN EX_JZERO =>
IF AC = x"0000" THEN
END IF;
STATE <= FETCH;
WHEN EX_AND =>
AC <= AC AND MDR;
STATE <= FETCH;
WHEN EX_OR =>
AC <= AC OR MDR;
STATE <= FETCH;
WHEN EX_XOR =>
AC <= AC XOR MDR;
STATE <= FETCH;
WHEN EX_ADDI =>
IF IR(9)='0' THEN
AC <= AC + ("000000"&IR(9 downto 0));
ELSE
AC <= AC + ("111111"&IR(9 downto 0));
END IF;
STATE <= FETCH;
WHEN EX_SHIFT =>
AC <= AC_SHIFTED;
STATE <= Fetch;
WHEN OTHERS =>
STATE <= FETCH; -- If an invalid state is reached, return to FETCH
END CASE;
END IF;
END PROCESS;
END a;
AC_SHIFTED is part of the state_type, and so has no specific value - the compiler will chose the value for you. If you want specific std_logic_vector values, you will need to specify them yourself.
You also get the error because you're trying to assign a value to an out port (you can only connect an output to a signal, not a constant or an input).
TO_BE_DONE
main code has lots of components as below , above errors are associated with component calls in the main alu code.
--LIBRARY USAGE
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_signed.all;
use ieee.numeric_std.all;
--ENTITY OF 64 BIT ARITHMETIC LOGIC UNIT
entity alu_64 is
generic(K :natural:=64) ;
port (input1 :in std_logic_vector(K-1 downto 0) ;
input2 :in std_logic_vector(K-1 downto 0) ;
alu_cont:in std_logic_vector(4 downto 0) ;
clk :in std_logic ;
reset :in std_logic ;
alu_out :out std_logic_vector(K-1 downto 0) ;
alu_rout:out std_logic_vector(K-1 downto 0) ;
flag_reg:out std_logic_vector(4 downto 0)) ;
end alu_64;
--BEHAVIORAL DESIGN ARCHITECTURE OF 64 BIT ARITHMETIC LOGIC UNIT
architecture behavioral of alu_64 is
-----------------------------DECLERARION OF MUTIAL REQUIREMENTS---------------------------------
--Mutual signal declerations
shared variable temp_alu_out :std_logic_vector(K-1 downto 0) ;
shared variable temp_alu_rout:std_logic_vector(K downto 0) ;
shared variable temp_flag_reg:std_logic_vector(4 downto 0) ;
shared variable CF :std_logic ;
shared variable OVF :std_logic ;
shared variable ZF :std_logic ;
shared variable PF :std_logic ;
shared variable SF :std_logic ;
--Mutual function decleration
--Carry Flag function decleration
function C_F(input : std_logic) return std_logic is
begin
if input = '1' then
return '1';
end if;
return '0';
end C_F;
--Overflow Flag function decleration
function OV_F(input : std_logic) return std_logic is
begin
if input = '1' then
return '1';
end if;
return '0';
end OV_F;
--Zero Flag function decleration
function Z_F(input : std_logic_vector) return std_logic is
begin
if input = x"00000000" then
return '1';
end if;
return '0';
end Z_F;
--Parity Flag function decleration
function P_F(input : std_logic_vector) return std_logic is
variable counter:integer:= 0;
begin
for i in 0 to K-1 loop
if(input(i) = '1') then
counter := counter + 1;
end if;
end loop;
if(counter mod 2 = 0) then
return '1';
end if;
return '0';
end P_F;
--Sign Flag function decleration
function S_F(input : std_logic) return std_logic is
begin
if(input = '1') then
return '1';
end if;
return '0';
end S_F;
--------------------------------ARITHMETIC UNIT DECLERARIONS-----------------------------------
--SIGNAL DECLERATIONS
--Signal declerations for ADD_64 (64 bit unsigned adder)
shared variable temp_add_out :std_logic_vector(K-1 downto 0);
shared variable temp_cout :std_logic;
--signal declerations for SADD_64 (64 bit signed adder)
shared variable temp_sadd_out :std_logic_vector(K-1 downto 0);
shared variable temp_scout :std_logic;
--signal declerations for SUB_64 (64 bit unsigned subtracter)
shared variable temp_sub_out :std_logic_vector(K-1 downto 0);
shared variable temp_borrowout :std_logic;
--signal declerations for SSUB_64 (64 bit signed subtracter)
shared variable temp_ssub_out :std_logic_vector(K-1 downto 0);
shared variable temp_sborrowout:std_logic;
--signal declerations for MULT_64(64 bit signed and unsigned multiplier)
shared variable temp_mult_out :std_logic_vector(2*K-65 downto 0);
--signal declerations for DIV_64 (64 bit signed and unsigned divisor)
shared variable temp_quotient :std_logic_vector(K-1 downto 0);
shared variable temp_remainder :std_logic_vector(K downto 0);
--signal declerations for MOD_64 (64 bit signed and unsigned modulator)
shared variable temp_mod_out :std_logic_vector(K downto 0);
TO_BE_DONE
Port maps cannot be connected to shared variables - they can only connect to signals.
