Nios 2 EDS not starting
Matthias0
Hi there,
i'm trying to get EDS to run on my Ubuntu 22.04. After following the README whichs content is duplicated here: https://www.intel.com/content/www/us/en/support/programmable/articles/000086893.html
I get several error messages when running ./eclipse-nios2.
The first one was:
xkbcommon: ERROR: failed to add default include path /tools/qt/5.15.6/1/linux64/rel/share/X11/xkb
My solution was to just create this path. After that i got:
xkbcommon: ERROR: 1 include paths could not be added:
xkbcommon: ERROR: /home/matthias/.xkb
xkbcommon: ERROR: Couldn't look up rules 'evdev', model 'pc105', layout 'us', variant '', options ''
to solve the path error i again just created it. But this "config" (?) file is missing.
Can someone help me out? What did i do wrong installing eclipse? How can i fix this?
Thanks in advance!
Matthias
ShengN_Intel
Hi Matthias,
Eclipse CDT 8.8.1 linux can be launched properly in both Ubuntu 18.04 and 20.04 LTS. Most likely still not being supported in Ubuntu 22.04 LTS yet may check out this OS support list https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-software/os-support.html. Probably have to stick with old Ubuntu first.
Best Regards
Sheng
HalmonCelman
I've encountered same problem and I found solution that works for me here:
https://community.intel.com/t5/Intel-Quartus-Prime-Software/Nios-II-SBT-Crashing-on-Linux/m-p/1210994
The solution that works for me:
instead of running ./eclipse-nios2
run in console:
export SWT_GTK3=0
export SWT_WEBKIT2=1
./eclipse-nios2
Hope it helps
HalmonCelman
