16592 Discussions
NiosII SBT4E post-processor action
I need someone's help in figguring out how to automatically call a script after each project build. I was not able to find out anywhere in the menus the Eclipse - typical pre-processor step or post-processor step.
What I want to do is call a Perl script once the .elf file is generated.
Any help appreciated. Thank you!
I was able to do it only by using the "advanced" section of the corresponding bsp. (as described here http://www.alterawiki.com/wiki/file:make_tricks_v1.0.doc
But how do I do it in the settings of the application only?
I need this because in my configuration I share one BSP with multiple applications running in the same hardware.
Thanks!
