All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
16488 Discussions
No HLS folder in Quartus Prime Pro 18.1
NSuku1
I only see a HLD folder and not a HLS folder in the Intel Quartus Prime Pro version.
Can you please verify?
Nivetha
AnandRaj_S_Intel
NSuku1
Hi Anand,
Does the patch works on 17.1 pro version as well?
Kindly confirm.
Nivetha
AnandRaj_S_Intel
​Hi Nivetha,
Apologies for late response,
The Intel HLS Compiler is included in the Windows release of Intel Quartus Prime Design Software Version v17.1.
However Patch is created for 18.1 Pro. You must either have previously installed the Quartus Prime 18.1 software or must install the Quartus Prime 18.1 software before installing this patch. Otherwise, the patch will not be installed correctly and the Quartus Prime software will not run properly.
Anand
