Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
No exact pin location assignment
I have made the following assignment in QSF using the pin assignment editor of Quartus-II. FPGA device is Stratix-V 5SGSMD4H1F35C1
set_location_assignment IOBANK_3A -to sink_N
set_location_assignment IOBANK_3B -to sink_data
set_location_assignment IOBANK_4B -to source_data
set_location_assignment IOBANK_4A -to source_exp
set_location_assignment IOBANK_7A -to source_N
set_location_assignment IOBANK_3A -to source_ready
set_location_assignment IOBANK_4B -to source_sop
set_location_assignment IOBANK_4B -to source_valid
set_location_assignment IOBANK_4B -to source_eop
set_location_assignment IOBANK_3A -to sink_ready
set_location_assignment IOBANK_3A -to sink_sop
set_location_assignment IOBANK_3A -to sink_valid
set_location_assignment IOBANK_8A -to Reset
set_location_assignment IOBANK_8C -to Clock
set_location_assignment IOBANK_3A -to sink_eop
Got warnings for all pins reporting " Pin --- not assigned to an exact location on the device"
Some warnings are reported below.
Info (169086): Pin sink_data[0] not assigned to an exact location on the device
Info (169086): Pin sink_data[16] not assigned to an exact location on the device
Info (169086): Pin sink_ready not assigned to an exact location on the device
Info (169086): Pin source_N[0] not assigned to an exact location on the device
Info (169086): Pin source_N[1] not assigned to an exact location on the device
Info (169086): Pin source_N[2] not assigned to an exact location on the device
Info (169086): Pin source_N[3] not assigned to an exact location on the device
Info (169086): Pin source_N[4] not assigned to an exact location on the device
Info (169086): Pin source_N[5] not assigned to an exact location on the device
Info (169086): Pin source_N[6] not assigned to an exact location on the device
Info (169086): Pin source_N[7] not assigned to an exact location on the device
Info (169086): Pin source_N[8] not assigned to an exact location on the device
Info (169086): Pin source_N[9] not assigned to an exact location on the device
Info (169086): Pin source_N[10] not assigned to an exact location on the device
Info (169086): Pin source_N[11] not assigned to an exact location on the device
Info (169086): Pin source_data[0] not assigned to an exact location on the device
Info (169086): Pin source_data[1] not assigned to an exact location on the device
Info (169086): Pin source_data[2] not assigned to an exact location on the device
Info (169086): Pin source_data[3] not assigned to an exact location on the device
Info (169086): Pin source_data[4] not assigned to an exact location on the device
Info (169086): Pin source_data[5] not assigned to an exact location on the device
Info (169086): Pin source_data[6] not assigned to an exact location on the device
Info (169086): Pin source_data[7] not assigned to an exact location on the device
Could you please suggest how to clear the warnings and fix the issues?
Highlighted
every single data bit has to be be assigned to a specific pin, not just IOBANKS
Highlighted
The fitter has done this exact pin assignment itself inside the IOBANKS as this is an experiment and the FPGA has not connected to any board. If its to be done manually, how to do this in a simple way.
Highlighted
Well, like you have in the original post - these are only warnings saying you have not assigned pins - not errors.
You could try assigning all outputs to virtual pins if this is only an experiment.
Highlighted
If you like what locations the Fitter has selected in the I/O banks, you can then back-annotate the locations it has selected to write exact locations to the .qsf file (Assignments menu).
Steve
