17093 Discussions
Nonresolved signal has multiple sources
Hi all, A homework task I got is to create a component which receives positive numbers and gives the output of A+B-C+D-E...
Compiling the code yields one error:
# ** Error: checkex4.vhd(103): Nonresolved signal 'cur_RES' has multiple sources. The signal "cur_RES" is the output of the FF whom is responsible for the memory for the next cycle. I don't see why there is a problem with the code. (I can guess it's connected to the clock and sync options ?)
The sketch which I have done for the component is:
https://www.alteraforum.com/forum/attachment.php?attachmentid=7227
(The code is attached to the question)
Thanks in advance, Amitai
(Virus scan in progress ...)
cur_reset is assigned 0 after begin then it is driven again by a component. So are some other signals. This is multiple drive and need to be resolved by user.
Thanks very much!
The program still doesn't work as expected and the output
has for some reason different clock time then the rest of the
circuit, any idea why?
Thanks, Amitai
According to your diagram, the right code is (without the double register)
if rising_edge(clk) then if Rst_n='0' then cs <= '0'; cr <= 0; else cs <= ns; cr <= cr + muxo; --cr <= nr; end if; end if;
To improve readability I would pull everything into the process.
if rising_edge(clk) then if Rst_n='0' then cs <= '0'; cr <= 0; else cs <= not cs; if cs = '0' then cr <= cr + D_in; else cr <= cr - D_in; end if; end if; end if;
P.S.: Different from your code, the diagram seems to suggest an asynchronous reset.
