Hi all, A homework task I got is to create a component which receives positive numbers and gives the output of A+B-C+D-E...
Compiling the code yields one error: # ** Error: checkex4.vhd(103): Nonresolved signal 'cur_RES' has multiple sources. The signal "cur_RES" is the output of the FF whom is responsible for the memory for the next cycle. I don't see why there is a problem with the code. (I can guess it's connected to the clock and sync options ?) The sketch which I have done for the component is: https://www.alteraforum.com/forum/attachment.php?attachmentid=7227 (The code is attached to the question) Thanks in advance, AmitaiLink Copied
cur_reset is assigned 0 after begin then it is driven again by a component. So are some other signals. This is multiple drive and need to be resolved by user.
Thanks very much!
According to your diagram, the right code is (without the double register)
if rising_edge(clk) then
if Rst_n='0' then
cs <= '0';
cr <= 0;
else
cs <= ns;
cr <= cr + muxo;
--cr <= nr;
end if;
end if;
To improve readability I would pull everything into the process.
if Rst_n='0' then
cs <= '0';
cr <= 0;
else
cs <= not cs;
if cs = '0' then
cr <= cr + D_in;
else
cr <= cr - D_in;
end if;
end if;
end if;
P.S.: Different from your code, the diagram seems to suggest an asynchronous reset.
