16602 Discussions
On a Stratix 10 MX FPGA, we haven't been able to run OpenCL code. After the setup, we experienced the error 534259 and tried to install the suggested patch from cmspsg.intel.com, but the server is down. Is there other site to download the file?
dariosg
Error 534259: https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/component/2018/why-does-my-stratix10-device-fail-to-configure-if-there-is-a-del.html,
Patch: https://cmspsg.intel.com/content/dam/altera-www/global/en_US/support/knowledge-center/components/2018/quartus-18.0-0.13-linux.zip
The version that we have installed in our machine to compile is aocl 18.1.0.222 (Intel(R) FPGA SDK for OpenCL(TM), Version 18.1.0 Build 222 Pro Edition, Copyright (C) 2018 Intel Corporation) with Quartus Prime Programmer Version 18.1.0 Build 222 09/21/2018 SJ Pro Edition
MuhammadAr_U_Intel
Hi, I am able to access the patch, can you try again ? Thanks, Arslan
dariosg
Hi Arslan,
Thanks for your help, but the patch is still not accessible as you can see in the attached screenshot. Also, I did a whois of cmspsg.intel.com and got a No match for domain "CMSPSG.INTEL.COM". Is there any other server where we can download the file?
Darío
MuhammadAr_U_Intel
Oki I understand the problem now, let me check on this.
MuhammadAr_U_Intel
Hi, You can try downloading the patch now. Let me know if you still face issue downloading it. Thanks, Arslan
dariosg
Hi Arslan,
Sorry but, cmspsg.intel.com is still not visible from outside. Whois still responds No match for domain "CMSPSG.INTEL.COM".
Darío
HRZ
Valued Contributor III
Check the knowledge base page again, the download link has completely changed and the new one works without issues.
MuhammadAr_U_Intel
Hi Dario, CMSPSG.intel.com being not accessible is expected as this is internal domain. I have updated the patch links to external domain. Thanks HRZ for confirming that new links are working. Regards, Arslan
dariosg
Hi @HRZ​ and @MUsman​,
Sorry, my bad. I didn't check the original link, and thanks a lot for your help.
Best,
Darío
