17255 Discussions
On-chip Debugging Design Examples .qar can't be loaded
astrocyte
I've downloaded the Systemconsole_design_example.qar from the URL provided under the documentation resources: https://www.intel.com/content/www/us/en/programmable/support/support-resources/design-examples/design-software/on-chip-debugging.html to help me get started with  System Console. Unfortunately, when I try to open the file in Quartus, I have an error that says "Project archive restoration failed. Your project may be corrupted.". Is there a different repository where I can find these examples? I'd appreciate if you could point me to any relevant resources for getting started with System Console (ideally also integration with MATLAB for Nios2 based designs).
SyafieqS
Hi Horia,
Can you navigate to below link and download Introduction to FPGA Simulation and Debug materials there?
https://software.intel.com/content/www/us/en/develop/topics/fpga-academic/materials-workshops.html
Design file you referred probably an old design I can see 10.1 release.
SyafieqS
Hi Horia,
astrocyte
Hi SyafieqS_Intel,
Excellent - thank you. I managed to configure my project for use with the System Console in the meantime, by adding a JTAG to Avalon Master Bridge. I'm writing ADC readings to On-Chip RAM using IOWR_32DIRECT and reading the values from the System Console using a TCL script. Having a quick look through the resources, I didn't find anything relating to reading the data directly from into Matlab.
My aim is to plot the ADC readings by accessing the On-Chip RAM from Matlab through the System Console/TCL. A search leads me to:
https://www.intel.com/content/www/us/en/programmable/products/design-software/fpga-design/quartus-prime/features/qts-systems-console.html
but these resources also seem to be outdated, because Flash is no longer supported. Is there a newer version of these?
EDIT: For context, I tried printf and bitbang to nios2-terminal, but it reduces the ADC sample rate (which is already limited by SPI transactions) by a considerable amount.
astrocyte
Great resources, I managed to optimize the design, achieving 159 SPS with 8 channels on and 1.2k SPS with 1 channel on - which should be sufficient. I'm still printing to the Nios2 terminal - the limiting factors were due to timing and there are more optimizations possible.
On a side note, I scripted a TCL adapter for reading the memory directly, but printing to JTAG UART still performs better.
