Hi
I'm working on Max10 Flash memory to write some image data from PC application to Max10 flash memory through USB 2.0, from USB iam getting 8 bit data for flash memory i have to store 32 bit data here iam confused Can i get any example design how to use flash memory in max10.
Thanks in advance.
Hi Kumar,
To use user flash memory in MAX10, you may refer to the user guide at link below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_ufm.pdf
Thank You.
