17255 Discussions
OpenCL compilations giving me errors
SBoda
Intel(R) FPGA SDK for OpenCL(TM), 64-Bit Offline Compiler
Version 17.1.1 Build 273
Copyright (C) 2017 Intel Corporatio
Quartus Prime Shell
Version 17.1.1 Build 273 12/19/2017 Patches 1.01dcp,1.02dcp,1.36,1.38 SJ Pro Edition
Copyright (C) 2017 Intel Corporation. All rights reserved.
SBoda
Log file quartus_sh_compile.log
ERROR: packager tool failed to run. Check installation. Aborting compilation!
HRZ
Valued Contributor III
Please attach your complete "quartus_sh_compile.log" and also mention your board model and OpenCL BSP version you are using.
SBoda
quartus_sh_compile.log: ERROR: packager tool failed to run. Check installation. Aborting compilation!
Borad: pac_a10
OpenCL BSP pv 1.2
KennyTan_Altera
Are you running DCP 1.0 PRQ? Have you installed OPAE as described in the below prior to compiling the kernel? https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qs-ias-v1-1.pdf
