17117 Discussions
Option to redirect Quartus logs (Infos, warnings,errors) to a custom log file
Sajith_K_Intel
Is there an option to redirect Quartus logs (Infos, warnings,errors) to a log file and know the progress while Quartus running in batch mode? currently, reports inside output_files are dumped at the end of process and I am unable to track its progress till the end.
Busy
I don't know if you are on Windows or Unix...
Did you try redirection?
Example on linux:
(quartus_map projectname) >> hw_compilation.log 2>&1
Does it answer your problem?
