16606 Discussions
Orthodox way for testbench in modelsim
According to Verilog spec,
initial
begin# 20 clk=1;
# 40 clk=0;
# 60 clk=1;
# 80 clk=0;
End
is legal, and can be compiled under modelsim. However, if we “run 200” from restart, during execution only the first delay# 20 is hit, and the following three executions are ignored.
Is this the excepted behavior?
Above is actually attempt to create Verilog testbench. We read through modelsim documents, and did find useful way to create customized waveform, i.e. using value dump file, although the testbench way is not working.
But no way seem to allow signal contention, or two wave definitions simultaneous to a single signal. For example, if we issue two commands:
force -drive sim:/I2C_to_GPIO/clk St1 0 -cancel 2000
force -drive sim:/I2C_to_GPIO/clk St0 0 -cancel 2000
the second one overrides first, which agrees with “force” command definition in modelsim_ref. But the definition
-drive
(optional) attaches a driver to the object and drives the specified <value> until the object is forced again or until it is unforced with the noforce command.
also says that drives can be attached, which I read as “allow multiple drivers”. How is this “multiple simultaneous driver” actually realized?
greg
An "orthodox" way to create a testbench is to not use force at all. Force overrides what is already on a signal, and really only meant for fault injection.
As for running the testbench, the run command runs for the time specified in the command, so run 200 should run the testbench for 200 ns.# 20 delays a signal for 20*timeprecision. What have you got timeprecision set to? if it is 10 ns, then that will mean# 20 = 200 ns.
Try running the simulation for longer.
Thanks. It was time unit problem.
