17049 Discussions
PCI-E hard IP in Qsys, external Interrupt connection
Hi All,
I am new to qsys tool....
I need to implement a system in Qsys using PCI-E bus.
System consist of PCI-E bus, 6 UART cores and other custom logics inside Altera FPGA interfacing with external host.PCI-E configured as End point only.
In Qsys I have added PCI hard IP, Avlon MM-slave translator, Clk component, Reset component and an Irq bridge.
There are 6 interrupts coming from 6 UARTs need to be passed to host through PCI-E using MSI mode. I am using UARTs from external vendors(not qsys components).
How these interrupt need to be connected to PCI-E? whether IRQ bridge is required? How I can connect UARTs interrupt to IRQ bridge?
How many IRQ bridges is required?
Thanks in advance..
zeal
Hi All,
pls see the attachment for better understanding of the problem...
If I instantiate one IRQ bridge with 6 interrupt inputs, I am not able to set the priority(like 0,1,2,..) at the sender port connection.
anybody faced similar issue??
Rgds,
zeal
