16556 Discussions
PCIe ip核,点击"generate example design"生成的tcl使用时报错;
xiaoxu
您好,
       在使用quartus prime 20.3版本生成ip核时,遇到以下两个问题:
       1)勾选上“simulation”之后,ip核生成不成功;
       2)使用ip核配置界面上的“generate example design”,只会生成一个tcl文件,用该tcl在tcl console界面运行时,tcl的第一行就会报错“Error:"package require -exact qsys 19.1"”。
Rahul_S_Intel1
Hi ,
Kindly sent the generated example design for my review.  So that I can recreate the issue in house, if the issue is valid, I will try to provide solution.
In my point of view, the generated example design should work.
xiaoxu
Thanks for support,look forwards to your test results and solution.
xiaoxu
I haven't contacted for a long time, how is the test result?
xiaoxu
Attached is the generated example design of  pcie ip core.
Rahul_S_Intel1
From my side , example design is working
xiaoxu
您好,
       您是直接生成的example design工程吗?还是生成的tcl,然后由tcl生成example 工程呢?我这边的quartus 使用的是官网上的评估版liscense,不知道是不是这个的影响?
