17253 Discussions
PLL Reconfiguration Timing Constraint
JLee25
  I have a question on the PLL timing constraint when working with Cyclone V Pll reconfiguration.
  In my case, I have the PLL output 2 different frequency, 1 is 10MHz and the other is 300MHz. Then I have to use the reconfiguration.
  Then how could I constraint the clock instead of using "derive_pll_clocks".
Thank you!
Farabi
Farabi
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
regards,
Farabi
