PLL issue
I am using cyclone IV E PLL to generate 2.5MHZ, 10MHZ and 40MHZ.
Although all output clocks are good, they are not locked between them.
Is there any settings I can modify to let them locked between them.
Many thanks.
What exactly do you mean by "locked between them"? If they are coming from the same PLL they will be in phase, if this is what you are looking after.
