17256 Discussions
Parametrically sized localparam assignment
I would like to be able to assign an array of localparams with some kind of static function. For example I don't want to have to do this:
localparam SIZE = 3; typedef logic bar_t; localparam bar_t FOO = {32'd1, 32'd2, 32'd3};
Because, while this works, it isn't fully parametric. I'd like to be able to do something like:
localparam SIZE = 3; typedef logic bar_t; function makeFoo (input integer size); bar_t bar; integer i; for (i = 0; i < size; i++) begin bar = i; end return bar; endfunction localparam bar_t FOO = makeFoo(SIZE);
Unfortunately, size inside of makeFoo isn't static (or at least Modelsim says it isn't).
Anyway, I'm wondering if anyone has a way to do this. I use static functions all the time to define simple localparam types, but this is proving more difficult.
Todd
So, to answer my own question, this appears to work, while not entirely elegant:
`define MAX_BAR 128 typedef logic bar_t; function bar_t makeFoo (input integer x); bar_t bar; integer i; for (i = 0; i < x; i++) begin bar = i + 1; end return bar; endfunction . . . localparam bar_t FOO = makeFoo(SIZE);
I'd like to be able to size everything only as large as I need it. But for static analysis, it's probably sufficient for most uses to set an upper bound like this.
Again, if anyone has a cleaner way to do this, I'd be interested to see it.
Try this:
module top; localparam SIZE = 3; typedef logic bar_t; typedef bar_t foo_t; function foo_t makeFoo; for(int i=0;i<$size(makeFoo);i++) makeFoo = i; endfunction localparam foo_t FOO = makeFoo; initial $display("%p",FOO); endmodule
Thanks for the response. I tried your suggestion and I get this from Modelsim:
** Error: /some/file.sv(427): (vlog-2118) The function 'makeFoo' is not a valid constant function. ** Error: /some/file.sv(427): Parameter value must be constant.
I'm currently running:
Model Technology ModelSim DE vsim 10.1 Simulator 2011.12 Dec 5 2011
which is clearly a bit old, so I'm not sure if that's part of the problem. I know that Modelsim (along with Quartus) does multi-pass static elaboration, but apparently it's having a problem with that here.
You will have to show more code. The example I showed above works in ModelSim 10.1. It works all the way back to ModelSim 6.3 if you add ()'s to FOO = makeFoo();
