17042 Discussions
Passing parameters to tcl scripts
Hi everyone! I made a simple tcl script to copy my .sof file to a network-disk folder, then convert the whole PFGA chain to the rbf format.
Is it possible to pass a parameter to the tcl script? I would like to give the name of the rbf file to the script, as a command line argument. The script is executed in the tcl consolle of Quartus II.
Up to now, the only way I could find is is to modify the tcl script with an editor. Anyone can help me? bye
Hi davide.camerano,
Command line arguments are stored in the list named 'argv'. You can get the first argument with "lindex $argv 0" and the second argument with "lindex $argv 1".
For example, assume that hoge.tcl contains the following:
puts "1st argument is [lindex $argv 0]"
If you execute the script as "quartus_sh -t hoge.tcl xxx", you will get the following output:
1st argument is xxx
Also you can use the cmdline package to specify command line arguments like -<option> <value> . For more information on the package, please refer to the page 3-37 in the following document.
http://www.altera.com/literature/hb/qts/qts_qii52003.pdf
Thanks for the help. I tried to insert a parameter in my script, based on your example, and it worked with the quartus_sh command from the windows xp command prompt, but it did not work from the quartus II tcl consolle, by using the "source script_name.tcl" command. Why?
The list 'argv' is not set when you source a tcl script.
Instead, you can define a procedure with 'proc', and call it after you source your script.
For example, suppose you have the following code in hoge.tcl. The code block defines a procedure named 'argument'. It takes two arguments.
proc argument {first second} {
puts "first=$first"
puts "second=$second"
To call the procedure, you need to source the script first:
tcl> source hoge.tcl
Then you can call it as follows. This example passes two arguments: aaa and bbb.
tcl> argument aaa bbb
The following will be output:
first=aaa
second=bbb
Hope this helps.
