architecture behave of convo is
signal rg: std_logic_vector(1 downto 0):="00";
signal c1: std_logic_vector(31 downto 0);
signal c2: std_logic_vector(31 downto 0);
begin
process(clk)
begin
if (clk 'event and clk='1') then
for i in 0 to 31 loop
c1(i)<=wr_data(i) xor rg(1);
rg(1)<=rg(0); :confused:
rg(0)<=wr_data(i); :confused:
end loop;
end if;
end process;
C1_out<=c1;
--C2_out<=c2;
end;
rg(0) is always assigned to wr_data(31), because signals take the last value assigned to them. did you mean for rg to be a variable?
--- Quote Start --- rg(0) is always assigned to wr_data(31), because signals take the last value assigned to them. did you mean for rg to be a variable? --- Quote End --- Yes I need rg(0) to be assigned to wr_data(i) ( same for assigning rg(1)) as you said rg should be variable every iteration
