17268 Discussions
Pin ~ALTERA_DATA0~ assignment
Hello!
Currently I'm facing the folling error message (Stratix III, EP3SL70):
Error: Can't place multiple pins assigned to pin location Pin_N21 (IOPAD_X0_Y32_N62)
Info: Pin USB_DATA[0] is assigned to pin location Pin_N21 (IOPAD_X0_Y32_N62)
Info: Pin ~ALTERA_DATA0~ is assigned to pin location Pin_N21 (IOPAD_X0_Y32_N62)
Actually, I'm not aware of such a pin (~ALTERA_DATA0~) nor does it show up in the pin planner nor the assignment editor. I did not actively define such a pin. How can I prevent this incident?
Anybody got an idea?
Peter
The assignment is under Device and Pin Options / Dual purpose pins. Here you have to specify "Use as general I/O" for Data[0] and possibly other configuration pins.
Works perfectly, thanks! ;-)
