17267 Discussions
Pin Migration Cyclone 10 GX
JLee25
I am using Pin Planner to verify the pin compatibility between C10GX150 and C10GX220.
I saw high lightened pins in bank 2L for unknown reason, please forward to attachment.
Should I skip this and suppose those 2 devices can work as well?
If not, then what should I do?
Thank you!
AnandRaj_S_Intel
Pin function or I/O back column will be NC.
  1. We have to Compare the PINOUT file and find the difference and check it with respect to pin connection guidelines
  2. If we are doing Quartus design migration we can change the device PN and compile the design and check.
Anand
AnandRaj_S_Intel
Hi Johnson,
Which version of tool are you using?
I have check it using Quartus 19.1 pro. Nothing is been lightened Attached the report.
Also try pin-out files comparison.
Anand
JLee25
Hi Anad,
Thank you for getting back.
I am using Quartus Prime Pro Edition Ver. 18.0.1 Build 261 for the fit.
If the migration has problem, what message it will show to indicate the error?
Johnson
AnandRaj_S_Intel
Anand
