17042 Discussions
Pin assignement from DE1 to DE nano
I have a VHDL code writen to work on a "DE1 ALTERA" developement board, now I want to run the same code on a "DEO nano" so that I can make a smaller circuit that can fit in my system. the problem is that I used a lot of GPIO pins and now I have to do all the pin assignement to mutch the "DEO nano":(. I wonder if there is any tool that can help me doing this fast. thak you
You can use the Terasic System Builder application that comes with the software tools from each of these boards. It can spit out a .qsf file that has all the device pins assigned to appropriate signal names.
I have done this in the past, and have the same GPIO assignments that works on both a DE1 and a DE0-Nano board.
