17040 Discussions
Pins must meet Altera requirements for 3.3, 3.0, and 2.5-V interfaces? What to do?
during Quartus compilation, the following warning message appears:
Warning: X pins must meet Altera requirements for 3.3, 3.0, and 2.5-V interfaces. Refer to the device Application Note 447 (Interfacing Cyclone III Devices with 3.3/3.0/2.5-V LVTTL/LVCMOS I/O Systems).
Info: Pin ABC uses I/O standard 3.3-V LVTTL at L21
Info: Pin XYZ uses I/O standard 3.3-V LVTTL at H1
What`s wrong?
Has somenone an idea to remove this warning?
Br,
Carsten
I got the same warning too,what can I do?
Nothing's wrong, and, AFAIK, you can't remove it.
It's just a reminder for you to take a look at the application note.
http://www.altera.com/literature/an/an447.pdf
I am getting below warnings on LCD data pins design for cyclone 4 device.I have also enabled the PCI clamp diode as per AN447 but still not able to resolve .could you please assist whats wrong here.
"Warning (169177): 8 pins must meet Altera requirements for 3.3-, 3.0-, and 2.5-V interfaces. For more information, refer to AN 447: Interfacing Cyclone IV E Devices with 3.3/3.0/2.5-V LVTTL/LVCMOS I/O Systems"
After enabling PCI doide as given below still getting same warnings.
LCD_DATA[0] Location PIN_Y2 Yes
LCD_DATA[0] I/O Standard 3.3-V LVTTL Yes
LCD_DATA[0] PCI I/O On Yes
Whereas as AN447 says its enabled by default : "If the input I/O standard is 3.3-V LVTTL, 3.3-V LVCMOS, 3.0-V LVTTL, 3.0-V LVCMOS, 2.5-V LVTTL/LVCMOS, PCI, or PCI-X, the PCI clamp diode is enabled by default in the Quartus II software.
Could you please suggest how I can remove these warnings.
Gagan
This warning is automatically generated as long as you use inputs with 2.5-3.3V vccio. There is no way to remove them, except by using explicitly the message suppression mechanism in Quartus.
