Platform Designer Error
Nitin1
I am getting this error when trying to Generate files using Quartus Standatd Edition version
Error: add_fileset_file: No such file C:/Users/nmistry/AppData/Local/Temp/alt8839_8898266765451528108.dir/0006_cpu_gen/simgen_tmp_0
while executing
"add_fileset_file "$file_name" OTHER PATH "$my_file""
(procedure "sub_add_generated_files" line 51)
invoked from within
"sub_add_generated_files "$NAME" "$output_directory" "$rtl_ext" "$simgen" "$plainTEXTfound""
(procedure "generate_with_plaintext" line 6)
invoked from within
"generate_with_plaintext "$NAME" "$rtl_ext" "$simgen""
(procedure "sub_sim_verilog" line 5)
invoked from within
"sub_sim_verilog niosii_system_nios2_cpu"
This error only started today and was not occuring before with this design
sstrell
Delete the directory named after the system and try to generate again.
Nitin1
sstrell
Your published output directory may be corrupted.  Keep the .qsys file and all other main files in your project directory and delete the folder generated by Platform Designer that has the same name as your system.  Then try to regenerate the system.
Nurina
Did the above reply solve your problem?
