Hi all,
I'm trying to generate the HDL files for a Cyclone-V SoC. Unfortunately, the generation fails with the attached messages:
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Error during execution of "{C:/intelfpga_lite/19.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Execution of command "{C:/intelfpga_lite/19.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt" failed
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: child process exited abnormally
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: add_fileset_file: No such file C:/Users/ALBERT~1.FAR/AppData/Local/Temp/alt9052_495511809790755470.dir/0004_seq_gen/hps_AC_ROM.hex
Error: border: Error during execution of script generate_hps_sdram.tcl: Generation stopped, 3 or more modules remaining
Error: border: Execution of script generate_hps_sdram.tcl failed
Error: border: 2022.03.01.09:06:53 Info:
Error: border: ********************************************************************************************************************
Error: border:
Error: border: Use qsys-generate for a simpler command-line interface for generating IP.
Error: border:
Error: border: Run ip-generate with switch --remove-qsys-generate-warning to prevent this notice from appearing in subsequent runs.
Error: border:
Error: border: 2022.03.01.09:06:57 Warning: Ignored parameter assignment device=5CSEBA2U19C8S
Error: border: 2022.03.01.09:06:57 Warning: Ignored parameter assignment extended_family_support=true
Error: border: 2022.03.01.09:07:02 Warning: hps_sdram: 'Quick' simulation modes are NOT timing accurate. Some simulation memory models may issue warnings or errors
There are more messages than this.
This same project compiles OK on a Linux platform, the failures are on a Win10 platform. I've tried Quartus 21 and 19 with a patch applied, and the same error persists. Unfortunately the Linux machine is just an old test device, and it takes quite a while to compile.
Any ideas, has anyone else experienced this? Happy to try other things if necessary.
Cheers,
Alberto
You can refer to below.
https://www.intel.com/content/www/us/en/support/programmable/articles/000086438.html
Hi, thanks for your reply. WSL2 is installed on the machine, but the link within the link provided does not work unfortunately!
Alberto
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
thanks, yes, the link and the solution did work well!
Cheers,
Alberto
