16343 Discussions
¿Por qué Quartus II no corre "Run funtional simulation" o "Run timing simulation"?
RGuzm4
Buenas tardes, estoy teniendo un problema para simular mi programa en Quartus II. Cuando genero el archivo .vwf, cuando presiono "Run funtional simulation" o "Run timing simulation", no sucede nada, no se abre ninguna ventana que muestre un error, no realiza ninguna acción
CalvinJoaz_P_Intel
Hi Rodrigo,
Good day to you.
Kindly provide the information as below.
  1. Which device you're using?
  2. Which Quartus II version you're using?
  3. Print screen of the following error.
Thank you.
RGuzm4
luckly I solved it, I erased all the blank spaces and special characters form the directory of the file and it worked, thanks for the help anyway
