17049 Discussions
Ports between blocks problem
hello every body,
I've multi blocks of "ram_infer" and the same number of "my entire program". I want to make the output of the entire program is the input to ram_infer, but facing error problem from QII.
is it correct to make on this way like below?
putting RA0-3 as an input and output on the same time.
Thanks in advance for your help. :)
wire [10:0] RA0;
wire [10:0] RA1;
wire [11:0] RA2;
wire [11:0] RA3;
generate
genvar i;
for (i = 0; i < IDE; i = i + 1)
begin : IDE_block
IDE u(global_reset_n, CLOCK_50, ram_din, di, RA0, RA1, RA2, RA3);
end
endgenerate
generate
genvar j;
for (j=0; j < SRAM_INFERS; j = j + 1)
begin: sram_block
SRAM_INFERS x(CLOCK_50, write_a, sram_we,DO, RA0, RA1, RA2, RA3, );
end
endgenerate
