17253 Discussions
Post Synthesis simulation fails, problem with RTL?
Hello all, I have a relatively simple state machine that works just fine for functional pre-synthesis simulation in Modelsim.
However, after running Quartus synthesis and fitter and extracting the post synthesis netlist (.vdo) the post synthesis simulation fails.
I have narrowed down the problem to a particular counter that counts correctly pre-syn but does not count at all post syn.
Here are the code segments. Does anyone see what I am doing wrong that causes Quartus to mis-interpret the "increment reg"?
I am using Quartus 13.
Thanks in advance for any suggestions.
--here is the increment register process--
inc_reg : process(clock, inc_reset, increment, increment_input)is
begin
if inc_reset = '0' then
increment_input <= "0000";
elsif rising_edge(clock) then
if increment = '1' then
increment_input <= increment_input + 1;
else
increment_input <= increment_input;
end if;
end if;
end process inc_reg;
--here are the states that should cause it to increment------------------------------
when key_data_input =>
inc_reset <= '1';
oe1 <= '1';-- send to chip
OE <= '0';
RD <= '1';
WR <= '0';
CS <= '0';
A0 <= '0';
DIR <= '0';-- FPGA to Chip
timer_start <= '1';-- counter
timer2_start <= '0';
data_start <= '0';
--output_enable <= '0';
if counter <= "001010" then
increment <= '0';
else
increment <= '1';
end if;
if increment_input = "0000" then
data_to_bus (7 downto 1) <= key (55 downto 49);
data_to_bus (0) <= parity0;
elsif increment_input = "0001" then
data_to_bus (7 downto 1) <= key (48 downto 42);
data_to_bus (0) <= parity1;
elsif increment_input = "0010" then
data_to_bus (7 downto 1) <= key (41 downto 35);
data_to_bus (0) <= parity2;
elsif increment_input = "0011" then
data_to_bus (7 downto 1) <= key (34 downto 28);
data_to_bus (0) <= parity3;
elsif increment_input = "0100" then
data_to_bus (7 downto 1) <= key (27 downto 21);
data_to_bus (0) <= parity4;
elsif increment_input = "0101" then
data_to_bus (7 downto 1) <= key (20 downto 14);
data_to_bus (0) <= parity5;
elsif increment_input = "0110" then
data_to_bus (7 downto 1) <= key (13 downto 7);
data_to_bus (0) <= parity6;
elsif increment_input = "0111" then
data_to_bus (7 downto 1) <= key (6 downto 0);
data_to_bus (0) <= parity7;
else
data_to_bus <= "00000000";
end if;
when key_data_input_pause =>
increment <= '0';
inc_reset <= '1';
oe1 <= '0';-- read chip
OE <= '0';
RD <= '1';
WR <= '1';
CS <= '0';
A0 <= '0';
DIR <= '1';-- Chip to FPGA
timer_start <= '0';
timer2_start <= '1';-- counter set mode
data_to_bus <= "11111111";
data_start <= '0';
when key_SRQ =>
increment <= '0';
inc_reset <= '1';
OE <= '0';
RD <= '1';
WR <= '1';
CS <= '0';
A0 <= '1';
timer_start <= '0';
data_start <= '0';
-- here are the state transitions----------------------------------------------------
next_state <= key_data_input;
else
next_state <= key_data_input_pause;
end if;
if counter_set_mode < "100000" then
elsif increment_input > "0111" then
next_state <= check_KPE;
else
next_state <= key_SRQ;
end if;
when key_SRQ =>
if SRQ = '1' then
else
end if;
You didnt post the whole code, so I have to assume you're using a 2 process state machine style?
increment appears to not be set in all states, so a latch will be created. Latches can have timing problems in hardware - so it is recommended that you avoid them.
Hi Tricky, yes I am using the traditional two process state machine. I did not post the whole code for brevity.
these are the only states that activate the increment process with the "increment" and "inc_reset" signals.
increment is actively controlled in all states, unless you are seeing something above that I am not.
No latches are inferred during the synthesis process.
Sorry I was confused by the way you posted the code - I thought the code at the bottom were extra states.
I highly suggest posting the whole code. Either use Code tags or attach the file.
