15892 Discussions
Power analysis and assignment of I/O Pins
shriram_INTL
Hi
For power analysis of my RTL code, I use Intel Quartus Prime Pro. I'm searching for help with parameters that determines the Power Analyzer.
So, could you please help me set up the parameters that define the power savings block?
I'd also like some help with the I/O Pin assignment.
Is there any example model that can show me how to assign smart I/O pins in both good and bad cases?
Thank you so much for reaching out in advance.
AqidAyman_Intel
Hi Shriram,
Thank you for the clarification. However, Power Analyzer is to calculate the power consumption of the design, so the user can refer to which the highest power consumed by the design and work from that point to improve their design to get more power saving.
Additionally, you can refer to this forum thread where the user shares one technique to improve power saving for FPGA designs.
Power saving techniques for FPGA
You also can check this article What are the Power Saving values based on in the Cyclone V and Arria..
Aqid
AqidAyman_Intel
Hello Shriram,
I hope you have a good day.
Can I know on the details what do you mean by the parameters that define the power savings block? On top of that, would you also explain on the good and bad cases meaning when u mentioned on the assigning smart I/O pins?
Aqid Ayman
shriram_INTL
Hello, Aqid.
With "what do you mean by the parameters that define the power savings block," I mean the Power Saving Summary in Quartus Prime Pro's compilation Report under the Power Analyzer section. Smart VID Power Savings and Power savings are shown here.
I'm wondering if there's a tuning option, such as a timing constraint, that can change the Power Saved statistic, or if it's all based on Verilog code.
Another point of view is Area vs. Power.
For example, I'm looking for I/O Pin assignment first, then erroneous I/O pins, because the number of pins (volts) versus area can result in better or lower power savings.
Thanks and best regards,
Shriram
AqidAyman_Intel
Hi Shriram,
Aqid
shriram_INTL
Thank you very much!! Your proposal is useful and it helped me in continue my investigation on my design.
best regards,
Shriram
