17267 Discussions
Problem compiling Matrix Mult example
When compiling the matrixmult example, I get this message below but with no indication as where the errors are!
Info (21057): Implemented 96131 device resources after synthesis - the final resource count might be different
Info (21058): Implemented 2049 input pins
Info (21059): Implemented 1713 output pins
Info (21060): Implemented 180 bidirectional pins
Info (21061): Implemented 77380 logic cells
Info (21064): Implemented 11389 RAM segments
Info (21065): Implemented 17 PLLs
Info (21066): Implemented 2 delay-locked loops
Info: Quartus II 64-Bit Analysis & Synthesis was successful. 0 errors, 162 warnings
Info: Peak virtual memory: 6531 megabytes
Info: Processing ended: Fri Jun 28 19:10:09 2013
Info: Elapsed time: 00:15:44
Info: Total CPU time (on all processors): 00:07:36
Error (281039): Finished parallel synthesis of 1 partition(s). 1 partitions did not finish parallel synthesis because there were errors
Error (281040): Partition "Top" did not complete synthesis due to errors
Info (144001): Generated suppressed messages file /work/altera/designs/matrixMult/matrixMult_pcie385n_d5/matrixMult/top.map.smsg
Error: Quartus II 64-Bit Analysis & Synthesis was unsuccessful. 2 errors, 56368 warnings
Error: Peak virtual memory: 19916 megabytes
Error: Processing ended: Fri Jun 28 19:31:18 2013
Error: Elapsed time: 06:02:40
Error: Total CPU time (on all processors): 01:56:21
The actual error is probably further up in the log file. Is there at least 16GB of RAM installed in the machine that was compiling the design?
The machine does have 16GB of RAM. I've checked the log file and there is no mention of any errors at all until the
I recommend opening a service request and having the support team at Altera take a look at the log file to see what is causing the issue: http://www.altera.com/mysupport
Also in the top level of the matrix multiplication directory is a readme file that explains how the prebuild .aocx files were generated. Did you use the same instructions or did you just call aoc without any flags?
I called aoc without any flags. I am rerunning now with the flags suggested in the README.txt
It would be frustrating if that turns out to be the root cause......
Using the flags in the README.txt seems to have fixed this.
SPere43
Hello guys,
I have the same error.
What's flags you update? I dont see anything, someone can help me?
