17258 Discussions
Problem during synthesization
I tried to synthesize my design in Quartus II version 8.0. During the synthesization, the error is:
Error (10394): VHDL error at zpu_core.vhd(874): left bound of range must be a constant
When i clicked this, the following is highlighted:
stackA(7 downto 0) <= unsigned(mem_read(((wordBytes-1-to_integer(stackA(byteBits-1 downto 0)))*8+7) downto (wordBytes-1-to_integer(stackA(byteBits-1 downto 0)))*8));
When i synthesize my design in Mentor Graphic HDL Designer, this is no problem at all. Maybe the Quartus that i'm using need to configured correctly?? Anyone has idea on this???
Thx
Does (wordBytes-1-to_integer(stackA(byteBits-1 downto 0))) contain a VHDL signal that can be changed to a variable? Quartus integrated synthesis can calculate the range bounds from variables but not from signals.
it doesn't contain signal that can be changed into variable.Maybe can i change some setting in my Quartus??
You can't make Quartus accept a signal in a range bound calculation.
So wordBytes, stackA and byteBits are all constants? My guess is some are signals, which Quartus Integrated Synthesis doesn't accept. I think(emphasize think) you could put this into a for-loop, where the integer goes from one of these values up to that plus 8.
Another concern, if I'm reading this correctly, is that mem_read seems to be some giant vector meant to be a RAM. For example, if you wanted a 256x8 RAM, you just made a signal that is 2047 downto 0 and then access it in 8 bit chunks. If that's what your intent is, I would suggest looking in the Quartus II Handbook at HDL coding guidelines for inferring a RAM, which is normally done with an array, so that the width is much more explicit than just inices that are i to i+8. I'm just taking a guess what you're doing, so ignore if that's not relevant.
I have such a problem too.
Were you able to solve?
--- Quote Start ---
--- Quote End ---
The problem above already has a solution.
You will have to post up your code to see what your problem is.
rc1_fifo_data(31 downto 0) <= rx_data((32*(conv_integer(state_counter(6 downto 1)))+31) downto (32*(conv_integer(state_counter(6 downto 1)))));
Expression above is in the case statement.
rc1_fifo_data is OUT std_logic_vector(32 downto 0)
rx_data is IN std_logic_vector((rx_num*32)-1 downto 0)
rx_num is generic integer
state_counter is an internal signal
when I tried to use variable instead of "conv_integer(state_counter(6 downto 1))" I got the same error message again; "left bound of the range must be a constant"
Am I wrong?
This again looks like you're trying to use rx_data like a memory. You should use an array, not a really wide std_logic_vector.
Please read the alter coding guidlines:
http://www.altera.com/literature/hb/qts/qts_qii51007.pdf
Actually this block is connected to the user-defined number of rx.vhd block whose output is std_logic_vector(32 downto 0).
I combined the rx.vhd blocks as rx_generic.vhd. So its output became a std_logic_vector(rx_num*32-1 downto 0). This forced me to use such a wide std_logic_vector.
But I couldn't understand how can I use array type in such a situation.
I can't define an IN port with array type, can I?
Or, Should I define an internal array and put the incomming 32bit datas to it then use?
yes you can use any type on a port declaration. The type has to be declared in a package.
As you said I defined such an array type in package whose dimensions were generic integers and used this array type in port decleration. In that case, I got errors again because I was not allowed to use generics, I had to use constants instead. This makes my control on my codes very complicated
I did the previous synthesis in Quartus 8.1 and as I said before it gave me such an error.
I think Quartus 9.1 is able to solve this case.
I didn't get such errors when I synthesized my code with Q9.1
I think Altera solved this "left bound of range must be a constant" issue in Q9.1 even we defined a long std_logic_Vectors with generic intergers.
