Hello every body;
I make a custom component and defined it in the Qsys tool, my custom component have an avalon mm slave bus; I faced a problem during analysing the component files in the component editor, the error is: *ERROR: avalon_slave_0: Slave with readdatavalid signal must support at least 1 pending read. Can any one help me; ThanksLink Copied
Read the description of the "maximumPendingReadTransactions" on page 3-6 of this document:
http://www.altera.com/literature/manual/mnl_avalon_spec.pdf It sounds like it is set to zero in your component.
