Good afternoon,
I'm trying to cascade two PLL's. Every PLL is fractional.
The first PLL gets Clock=75 MHz at its refclk port.
Then, I'm taking the signal from its cascade_out port and connect it to adjpllin port of second PLL.
First PLL gets RESET='0' constant,the second PLL gets RESET from inverted locked port of first PLL.
Unfortunately, nothing happens during simulation -the outputs of second and first PLL are red.
What is wrong with my cascading? Why simulation doesn't work?
Hi guys,
Do you have something new about this issue?
Let me recreate the issue and will update you , in mean time kindly reset the first PLL for some period of time then try to obtain the data
Hi ,
I had my simulation in Model sim and found it is wokring
Hi ,
Kindly let me know, if you need further assistance.
