16597 Discussions
Problem with aocl install
I have a problem with the installation command "aocl install<path_custom_platform>", because of the bash returns the following problem:
"is not an object at /home/intel_tools/intelFPGA_pro/17.1/hld/share/lib/perl/acl/Command.pm line 1290, <F> line 34." I am using a virtual machine with centOS 7.4 on Windows server 2012 R2. I attached the screenshot of the problem. Can anyone help me? Thanks for your help.
check your username and read/write perms of the path.
Could you try to use the supported operating system? 7.4 is not in our list
http://dl.altera.com/requirements/17.1/
CloseCL
(This message was posted on behalf of Intel Corporation)
now I am using OpenCL on centOS 6.8 (a version included in the above list) but it does not still work. I am using a virtual machine (Hyper-V) on Windows Server 2012 R2, should it be the problem? This is what the terminal returns:
[leonardo1@leonardo1 hld]$ aocl install
Do you want to install /home/intel_tools/intelFPGA_pro/17.1/hld/board/a10_ref? [y/n] y
aocl install: Running install from /home/intel_tools/intelFPGA_pro/17.1/hld/board/a10_ref/linux64/libexec
Looking for kernel source files in /lib/modules/2.6.32-642.el6.x86_64/build
Using kernel source files from /lib/modules/2.6.32-642.el6.x86_64/build
Building driver for BSP with name a10_ref
make: Entering directory `/usr/src/kernels/2.6.32-642.el6.x86_64'
CC [M] /tmp/opencl_driver_Qh2IhR/aclpci_queue.o
CC [M] /tmp/opencl_driver_Qh2IhR/aclpci.o
CC [M] /tmp/opencl_driver_Qh2IhR/aclpci_fileio.o
CC [M] /tmp/opencl_driver_Qh2IhR/aclpci_dma.o
CC [M] /tmp/opencl_driver_Qh2IhR/aclpci_pr.o
CC [M] /tmp/opencl_driver_Qh2IhR/aclpci_cmd.o
In file included from /tmp/opencl_driver_Qh2IhR/aclpci_cmd.c:53:
include/linux/aer.h:38: warning: ‘struct pci_dev’ declared inside parameter list
include/linux/aer.h:38: warning: its scope is only this definition or declaration, which is probably not what you want
include/linux/aer.h:39: warning: ‘struct pci_dev’ declared inside parameter list
include/linux/aer.h:40: warning: ‘struct pci_dev’ declared inside parameter list
include/linux/aer.h:57: warning: ‘struct pci_dev’ declared inside parameter list
LD [M] /tmp/opencl_driver_Qh2IhR/aclpci_a10_ref_drv.o
Building modules, stage 2.
MODPOST 1 modules
CC /tmp/opencl_driver_Qh2IhR/aclpci_a10_ref_drv.mod.o
LD [M] /tmp/opencl_driver_Qh2IhR/aclpci_a10_ref_drv.ko.unsigned
NO SIGN [M] /tmp/opencl_driver_Qh2IhR/aclpci_a10_ref_drv.ko
make: Leaving directory `/usr/src/kernels/2.6.32-642.el6.x86_64'
Best Regards
I afraid i am not able to comment much when using with virtual machine, do you confirm all the permission or admin rights?, as my own setup was just working with a centos6.8 with out any additional settings.
CloseCL
I also have that problem !!! Even I try it with sudo, I still get same result
Is any solution? Thanks.
Hi all,
I am also stuck with this problem. Has someone found a solution yet?
Best,
Eric
Same problem here. No solution found so far.
And the workaround is??
Click on "this workaround" posted by nicolacdnll
--- Quote Start ---
--- Quote End ---
You probably didn't see the link that reads:
--- Quote Start ---
Workaround
To avoid this error, apply following changes to the <OpenCL SDK Installation Path>/share/lib/perl/acl/Command.pm: lines 110 &111
Line 110: Replace isWindowsOS() ->acl::Env::is_windows()
Line 111: Replace mysystem_full({}, @cmd); -> system(@cmd);
--- Quote End ---
Thanks guys! I totally overlooked it, very sneaky...
I just wanted to add that it seems this was fixed in SDK v17.1 Update 1.
The update release notes (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/rn/rn_qts_dev_support_update.pdf) at page 18 reads:
Fixed an issue where the aocl install command failed with message similar to the following example: is not an object at <path_to_command.pm>/Command.pm line 1241, <F> line 68.
--- Quote Start ---
--- Quote End ---
I don't think it has been released yet, at least, I can't find it...
--- Quote Start ---
--- Quote End ---
It was released a while ago and they already released a newer version, namely Update 2, go to http://dl.altera.com/opencl/17.1/?edition=pro&download_manager=direct and select Update tab.
But, make sure your board vendor has a BSP for this version of the SDK.
Saikiranbelana
Iam trying to dockerize intel_rte_stack. After dockerization, the docker container was able to detect fpgas attached via PCIe  with
fpgainfo fme
 Output:
root@4a694037e7ce:~# fpgainfo fme
Board Management Controller, microcontroller FW version 26895
Last Power Down Cause: POK_CORE
Last Reset Cause: None
//****** FME ******//
Object Id                     : 0xEF00000
PCIe s:b:d:f                  : 0000:86:00:0
Device Id                     : 0x09C4
Socket Id                     : 0x00
Ports Num                     : 01
Bitstream Id                  : 0x124000200000367
Bitstream Version             : 1.2.4
Pr Interface Id               : 38d782e3-b612-5343-b934-2433e348ac4c
Boot Page                     : user
But when I try to run aocl install, the following errors occurs and it says, Intel PAC device
root@4a694037e7ce:~/intelrtestack/a10_gx_pac_ias_1_2_1_pv/opencl# aocl install
Do you want to setup the FCD at directory /opt/Intel/OpenCL/Boards [Y/n] Y
aocl install: Setting up the FPGA Client Driver (FCD) to the system. This process may require admin privilege
Install the FCD file to /opt/Intel/OpenCL/Boards
aocl install: Adding the board package /root/intelrtestack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp to the list of installed packages
Installing the board package driver to the system.
aocl install: Running install from /root/intelrtestack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/libexec
WARNING: Intel PAC device not found
Can someone please help me out in resolving these issues or if you have some proper documentation, please share
