17128 Discussions
§Problem with bidirectional pin 10CL006YU256A7G
RBell9
I have problems using a bidirectional pin in the cyclone 10LP custom board (10CL006YU256A7G).
I am using a bdf project, here is the implementation of the bidirectional pin:
on my board connected with the IN_OUT pin there is the following electrical circuit:
the problem is that when I set the OE line to LOW (bidirectional pin should transfer out the A value) the IN_OUT line remains HIGH regardless of the value of the A-line, the same happens when I put the OE LOW. The input signal remains HIGH even if I put the IO_PIN of the 'analog part' to gnd.
I tried to disconnect all the electrical parts but nothing changed.
If I use an output pin instead of a bidirectional one the output works fine (A signal is reported to the output pin).
I am using the pin L2, I tried to change the pin from L2 to T14 and all starts working fine, I also tried to connect the T14 pin to the same electrical circuit, and everything works.
There are some differences between these 2 pins? Do I have to change some properties of the L2 pin?
Thanks a lot
Farabi
Hello bidirectional pin can be set at pin planner.
You dont need to do the bdf circuit like you showed.
regards,
Farabi
Farabi
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
regards,
Farabi
