Greetings.
I am trying to program my configuration device (Numonyx M25P16, same size as EPCS16) via the JTAG port of a Cyclone4E EP4CE30F23 using Quartus v9.1sp2. When I try programming the device, I get a 'verification failed for device number 1' error. I know my configuration device is connected and working properly because I can successfully program it using a NIOS2 processor and an EPCS flash controller from within the fpga itself. I have created a .jic file via the Quartus 'Convert Programming Files...' feature. My settings are as follows: Config Device: EPCS16 File Name: PS850.jic Memory Map File is checked Flash Loader : EP4CE30 SOF Data : PS850.sof, EP4CE30F23, page_0, <auto> In the Quartus programmer, I select the PS850.jic file and select the 'Program/Configure' and 'Verify' checkboxes for the SFL image and PS850.jic. Here is what Quartus tells me: Info: Started Programmer operation at Mon Apr 11 17:41:23 2011 Info: Configuring device index 1 Info: Device 1 contains JTAG ID code 0x020F40DD Info: Configuration succeeded -- 1 device(s) configured Info: Device 1 silicon ID is 0x14 Info: Erasing ASP configuration device(s) Info: Programming device(s) Info: Performing CRC verification on device(s) Error: Verification failed for device number 1 Error: Operation failed Info: Ended Programmer operation at Mon Apr 11 17:41:38 2011 Any help would be greatly appreciated Thank you Scott WildLink Copied
Looks like upgrading to 10.1sp1 fixes this problem.
