I start Timequest timing analysis with constraints for a simple project, a NIOS-II processor, a PIO, an SPI and an SSRAM interface. Although I followed the Altera documentation of "Using SOPCBuilder with Quartus II Software" and "Constraining SOPC Builder Designs with TimeQuest", I get a few warning messages as follows.
Info: Design is not fully constrained for setup requirements Info: Design is not fully constrained for hold requirements unconstrained path From To From clocks inst|the_pll|the_pll|altpll_component|pll|clk[2] sram_clk clkin Because the path between inst|the_pll|the_pll|altpll_component|pll|clk[2] and sram_clk are specified, I don't know why I get this warning message. I attach my project here. Help please, many thanks.Link Copied
Hi bcao,
I believe you can set it to false path with the following command unless specifc tCO/min tCO for the output port is required: set_false_path -to [get_ports sdram_clk]- Mark as New
Thanks, golgo
I don't think that I can specify tCO/min tCO in the TimeQuest? Yes, I can by set_false_path -to [get_ports sdram_clk] to get rid of the warning message but the path to sram_clk is not a false path.
