17253 Discussions
Problems with VHDL lookup table
I'm trying to debug a Cyclone design which writes values taken from a
lookup table to the address inputs of a crosspoint analog switch. The
problem is that everything looks OK in the Quartus simulator, but when
I test the design on the target hardware it seems to be pulling the
wrong values out of the LUT. I have tried enabling SignalTap and
probing the output pins during the write operation, SignalTap reports
correct operation but the outputs, as measured on a real logic
analyser, are wrong.
E.g. for CHANNEL=1, eeprom_en='0', path=0 I should get 0,0,0,0,B,A,
3,2, I actually get 0,0,0,0,9,8,3,2
The lookup table is implemented thus:
Code:
There are 3 instances of this code in the design, with different
switch mappings selected by the CHANNEL parameter. They all show the
same problem, 'B','A' is consistently replaced by '9','8'.
I can't resolve this discrepancy I'm seeing between what the tools are
telling me and the behaviour when running on the target. The internal
PLL is being used to generate a 57.6 MHz global clock; Quartus timing
analysis shows f_max as about 85 MHz so i don't think it is a timing
issue. I have checked the pin assignments by driving the AX outputs
with a 4-bit counter which cycles continuously, this works correctly
as seen on the simulator and the external logic analyser.
Any ideas?
TIA
R.
Synchronise your design. Currently it is asynchronous.
--- Quote Start ---
Any ideas?
TIA
R.
--- Quote End ---
Try to use binairy values instead of hex values. I've had problems in the past with the x-prefix. So replace x"A" with "1010" and x"B" with "1011" and so on.
Ton
TO_BE_DONE
have you tried building this with and array rather than a load of literals? that is the altera recommended coding style for a rom.
--- Quote Start ---
--- Quote End ---
When even SignalTap reports correct behavior, it looks like a problem that is related to your hardware somehow, e.g. an incorrect pin-out, bad soldering-joint or a short-circuit between two pins, etc. Have you measured also with a scope to see if you get clean logic-levels on the outputs?
Thomas
OK, all resolved now.
The LUT was behaving as designed all along - but the analog switch IC has non-sequential mapping of AX addresses to analog channels! This info got lost between myself and the guy testing the hardware.
[Must read the datasheets a bit more thoroughly next time]
Thanks to all who replied.
