Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Programming Flash memory failed
I am using CycloneIII FPGA, Quartus11.1sp1 & NIOS IDE tool.
I am able to load sof file using quartus tool.
I need to burn sof file using NIOS IDE tool into my flash memory using JTAG.
when i tried to burn flash i am getting below error messages continuously.
erase failed at offset d0000
programming at a0000 failed... the address is not constant every time, it is changing randomly.
I tried more than 30 to 40 times but still error is coming.My data transfer from FPGA to PC is through Ethernet(TCP/IP) protocol. Once the flash is programmed i can ping my FPGA board using Ethernet protocol.
I have given all the setting in NIOS project build.
note: This NIOS IDE project is working for all the FPGA's except few.
We verified all the voltage and current levels of our board ... looking everything is fine.
I am attaching the my NIOS IDE project settings and error msgs.
Any one please help on this.....
