Hi
I'm trying to program my CPLD, but when I plug the USB blaster and start the tool Programmer, I have the error 44. What can I do with that? Maybe I've made some mistake with the VCCint and VCCIO pins. On my proto all the VCC are linked, is this a mistake? I've done this because I power the CPLD in 3.3V and my outs are in 3.3 too. I've seen that all the VCC pins must be connected. I don't remember if TCK TMS need a pull up or down resistor, maybe it is my mistake. Thanks for helpingLink Copied
I've forgotten to put ground and VCC of the JTAG but it did not work anyway.
I put the entire error message
Error: Can't access JTAG chain Error: Unexpected error in JTAG server -- error code 44 Error: Operation failed Maybe it can help- Mark as New
hi,
i have an EPM570GT100C5N MAX II CPLD and get exactly the same errors on Quartus II 9.0, 9.1 and 11.0. Could you solve the problem meanwhile, please? Cheers MIchael- Mark as New
Have you solved this problem?
I'm getting the same error with MAX V, 5M570ZT100C4N , My VCCIO and JTAG at 3.3V Anything?- Mark as New
Yes, you have to add pull resistor, check if your programmer need that target CPLD is powered before programming.
example schematic (http://elecfreaks.com/store/download/datasheet/dev%20platform/fpga/epm240.pdf) Connecting Vio and Vint together is ok, check if there are enough decoupling capacitor
