16336 Discussions
Proper way of connecting EPCQ configuration to Nios II-based system
YMona
Hi All!
What is correct IP to connect EPCQ32-A configuration flash to Nios II-based system (on Cyclone IV). There are four options in Quartus 18.1:
  1. Legacy EPCS/EPCQx1 Flash controller
  2. Serial Flash Controller
  3. Serial Flash Controller II
  4. Generic Serial Flash Interface
Nios II boots from EPCQ starting at some address (after fpga image).
The main problem is that we are unable to use quartus_pgm utility with --nios2 command line flag. We tried all of the IPs above, but it fails in different ways:
  1. Unable to reset and pause target processor
  2. Unable to erase flash
  3. Verify step passes, erase step fails
  4. Unable to locate CSR register while erasing (--erase_all option), but programming works ok with same --csr setting
  5. Crashing with access violation after correct programming (this is with option #2, but only if EPCQ base address is not 0x0)
Access violation arrives every time quartus_pgm exits with success (code 0x0).
Is there any reference design or template for this configuration (Cyclone IV, Nios II, EPCQ-A)?
Yurii
YMona
I think I've figured out the root cause of all problems. EPCQ reset was not connected to Nios II debug_reset_request signal.
But the problem with access violation persists. Every time quartus_pgm finishes programming of EPCQ flash (with --nios2 option)
it returns code 0x0 and programs everything correctly, but displays an access violation message.
Below is the full log of quartus_pgm utility. First it programs *.sof file, then programs *.flash files.
Info: *******************************************************************
Info: Running Quartus Prime Programmer
   Info: Version 18.1.0 Build 625 09/12/2018 SJ Lite Edition
   Info: Copyright (C) 2018 Intel Corporation. All rights reserved.
   Info: Your use of Intel Corporation's design tools, logic functions
   Info: and other software and tools, and its AMPP partner logic
   Info: functions, and any output files from any of the foregoing
   Info: (including device programming or simulation files), and any
   Info: associated documentation or information are expressly subject
   Info: to the terms and conditions of the Intel Program License
   Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
   Info: the Intel FPGA IP License Agreement, or other applicable license
   Info: agreement, including, without limitation, that your use is for
   Info: the sole purpose of programming logic devices manufactured by
   Info: Intel and sold by Intel or its authorized distributors. Please
   Info: refer to the applicable agreement for further details.
   Info: Processing started: Wed Feb 06 12:37:53 2019
Info: Command: quartus_pgm -c "USB-Blaster [USB-0]" -m jtag -o p;mk.sof
Info (213045): Using programming cable "USB-Blaster [USB-0]"
Info (213011): Using programming file mk.sof with checksum 0x00BECB69 for device
 EP4CE40F23@1
Info (209060): Started Programmer operation at Wed Feb 06 12:37:54 2019
Info (209016): Configuring device index 1
Info (209017): Device 1 contains JTAG ID code 0x020F40DD
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Wed Feb 06 12:37:57 2019
Info: Quartus Prime Programmer was successful. 0 errors, 0 warnings
   Info: Peak virtual memory: 298 megabytes
   Info: Processing ended: Wed Feb 06 12:37:57 2019
   Info: Elapsed time: 00:00:04
   Info: Total CPU time (on all processors): 00:00:01
   Info: Processing started: Wed Feb 06 12:37:57 2019
Info: Command: quartus_pgm --nios2 -c "USB-Blaster [USB-0]" --base=0x800000 --de
vice=1 --epcq --csr=0xc00000 --program mk.flash
Info (18932): Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Info (18932): Resetting and pausing target processor:
Info (18932): OK
Info (18932):              : Checksumming existing contents
Info (18932): 00000000     : Verifying existing contents
Info (18932): 00010000     : Verifying existing contents
Info (18932): 00020000     : Verifying existing contents
Info (18932): 00030000     : Verifying existing contents
Info (18932): 00040000     : Verifying existing contents
Info (18932): 00050000     : Verifying existing contents
Info (18932): 00060000     : Verifying existing contents
Info (18932): 00070000     : Verifying existing contents
Info (18932): 00200000     : Verifying existing contents
Info (18932): 00210000     : Verifying existing contents
Info (18932): 00220000     : Verifying existing contents
Info (18932): 00230000     : Verifying existing contents
Info (18932): 00300000     : Verifying existing contents
Info (18932): 003C0000     : Verifying existing contents
Info (18932): 00200000     : Reading existing contents
Info (18932): 00210000     : Reading existing contents
Info (18932): 00220000     : Reading existing contents
Info (18932): 00230000     : Reading existing contents
Info (18932): 00300000     : Reading existing contents
Info (18932): 003C0000     : Reading existing contents
Info (18932): Checksummed/read 850kB in 0.0s
Info (18932): 00200000 ( 0%): Erasing
Info (18932): 00210000 (16%): Erasing
Info (18932): 00220000 (33%): Erasing
Info (18932): 00230000 (50%): Erasing
Info (18932): 00300000 (66%): Erasing
Info (18932): 003C0000 (83%): Erasing
Info (18932): Erased 384kB in 0.0s
Info (18932): 00000000 ( 0%): Programming
Info (18932): 00010000 ( 0%): Programming
Info (18932): 00020000 ( 0%): Programming
Info (18932): 00030000 ( 0%): Programming
Info (18932): 00040000 ( 0%): Programming
Info (18932): 00050000 ( 0%): Programming
Info (18932): 00060000 ( 0%): Programming
Info (18932): 00070000 ( 0%): Programming
Info (18932): 00200000 ( 0%): Programming
Info (18932): 00210000 ( 7%): Programming
Info (18932): 00220000 (15%): Programming
Info (18932): 00230000 (22%): Programming
Info (18932): 00300000 (30%): Programming
Info (18932): 003C0000 (37%): Programming
Info (18932): Programmed 719KB +131KB in 0.0s
Info (18932): Did not attempt to verify device contents
Info (18932): Leaving target processor paused
   Info: Peak virtual memory: 268 megabytes
   Info: Processing ended: Wed Feb 06 12:38:24 2019
   Info: Elapsed time: 00:00:27
   Info: Total CPU time (on all processors): 00:00:00
*** Fatal Error: Access Violation at 0X000007FEF32E15C3
Module: quartus_pgm.exe
Stack Trace:
   0x115c2: AJI_CLIENT::disconnect_all + 0xc2 (jtag_client)
   0x21c37: DllMain + 0x27 (jtag_client)
   0x22420: __DllMainCRTStartup + 0x8c (jtag_client)
   0x3778a: LdrShutdownProcess + 0x1da (ntdll)
   0x3c1df: RtlExitUserProcess + 0x8f (ntdll)
   0x229a6: _initterm_e + 0x21a (MSVCR120)
   0x22cf1: __tmainCRTStartup + 0x125 (quartus_pgm)
   0x159cc: BaseThreadInitThunk + 0xc (kernel32)
   0x5385c: RtlUserThreadStart + 0x1c (ntdll)
End-trace
Quartus version is 18.1, running on Windows 7 x64.
Yurii
AnandRaj_S_Intel
Can you try to program example given in the link also follow the steps from AN736
https://fpgawiki.intel.com/wiki/User_talk:Booting_NIOS_II_from_Altera_Serial_Flash_Controller_(EPCQ)_with_blinking_LEDs_design_example
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an736.pdf
Let me know if your are able to program it or if you need any further assistance.
Anand
YMona
Hi, Anand
We have solved all problems with hardware right now (please read log in my second message). The only problem
is that quartus_pgm --nios2 crashes with access violation after successful programming. This problem is also
present in Quartus 17.1 with the same trace message.
As a solution, I've moved from using quartus_pgm with --nios2 flag to JIC-file based programming flow.
I've composed JIC-file with SOF data, Nios II program, DSP program and custom settings.
And it works perfectly (erasing only modified regions) and programming succeeds every time.
Yurii
